Generac Generator
hbauer
04-15-2007 09:48:19
This isn"t strictly Farmall, but I thought some of you guys might be able to help with a problem with my Generac portable generator. Was in storage 2 years, started right up.....ten second later shut down automatically because of "low oil switch". Oil was good, but I changed it anyway. Still shuts down.
I took out the plug and squirted oil on the cylinder - still shuts down after 10 seconds.
Any ideas? Oil filter could be clogged, but since it was brand new two years ago and only run about 5 hours, I doubt it. Should I bypass the switch?
Hate to ruin the generator, but I can"t see how it isn"t getting oil. Any thoughts?
Janicholson
04-15-2007 13:46:24
 Re: Generac Generator in reply to hbauer, 04-15-2007 09:48:19
Here is my input I have only ideas, no experience with that unit. If there is no oil pressure because the oil pump lost prime, then you have good reason not to run it. If there is low oil in the crank case then you have, again, good reason to not run it. Check where the low oil switch is placed, if it is in an oil gallery, I would pull it out and squirt about 100 pumps of engine oil into the gallery with a pump squirt oil can, with a rubber hose adapted to the hole. If it will take no oil that way, I would put a pressure gauge in the hole to be certain there is pressure befor assuming so. I hope this helps, Call or Email the manufacturer to obtain the needed information. JimN
Bob
04-15-2007 11:11:42
Are you SURE it's the oil level switch shutting down the engineby "killing" the spark?
More likely, there is a restriction in the fuel system, and it takes a while for the carb to fill. Then, when you start it, runs 'til the float bowl is empty of gas, then "dies".
