1942 Model M Serial Number 56608xiI'm just trying to tune up my newly aquired model M. It's running smooth with the exception of the occasional miss when idling. However, I've run into a few questions that I need help with - I've ordered the service manual but it probably won't be here till later in the week. Any advice is greatly appreciated. Carb tuning - What are the 3 different screws for - Tell me if I'm right here. *The one on the top from the governor input seems to be just for that - adjusting the governor. *The screw just below that seems to be for the idle mixture or idle speed adjust. *The screw near the bottom of the carb seems to be for the air/fuel mixture adjustment. *Can anyone give me the basic procedure for carb tuning? Also-- What spark plug is recommended for this tractor? The plugs that are currently installed seem to be shorter than they should be. What weight oil should I be using for the summer? I'm in Colorado near Loveland. I'm guessing that the way to check the oil level is via the two little valves on the side of the oil pan - right? How do I check the oil level in the transmission? Thanks again for any advice.
