Order Farmall Cub Parts Online
Three Cubs, 2 run, $2500
Aaron Ford
04-15-2007 20:50:48
My friend wants to sell three cubs he took in on trade. He has the belly plows and a sickle bar, that go with it, I believe. Conditions are 6/10, 5/10, and 3/10. The non-running one is missing it's carb and manifold. One has wheel weights all the way around, one in rear only and the last has no weights. There is also a set of mains on wheels that are included. Post here with your email open and I will forward the name and contact information.
Aaron
Aaron Ford
04-16-2007 10:39:34
 Re: Three Cubs, 2 run, $2500 in reply to Aaron Ford, 04-15-2007 20:50:48
Oh, and they are in Ripley, WV 25271
Aaron
Aaron Ford
04-16-2007 10:37:32
Hello, I am aware of the classifieds, but as I am not the seller I am not sure I can do this. I also cannot post the sellers info online so there is the second snag. Sorry about the misuse of the forum, it is not intended to make me any money. Just trying to hook good folks up with rebuildable tractors that I find, but have no interest in. I am a Massey man!
Anyhow the three tractors go together with all equipment for the price listed. Post a reply and I will email you the contact info.
Hope this explains things a little better.
Aaron
Nat 2
04-16-2007 09:51:48
There is a classified section on this website that will reach a wider audience. You might want to consider posting there.
Mike CA
04-16-2007 10:36:39
 Re: Three Cubs, 2 run, $2500 in reply to Nat 2, 04-16-2007 09:51:48
He may want to give the Farmall people first crack.
Just a thought.
MLD
04-16-2007 08:50:35
Sounds like it might not be a bad deal??
Mike CA
04-16-2007 07:29:13
Ahhh, I thought as much, but didn't want to assume.
Mike CA
04-15-2007 21:59:49
What do you mean by "conditions" of 6/10, 5/10, and 3/10?
Where are they located?
And is it $2500 for all 3, or each?
gene bender
04-16-2007 04:15:56
 Re: Three Cubs, 2 run, $2500 in reply to Mike CA, 04-15-2007 21:59:49
MIKE 6-10 is on a grade of 1-10 a 6
