What tractor does tihs plow fit??
old
04-16-2007 11:41:52
Got an IH plow yesterday but have no idea of what tractor it might go with. The number on the main beam is PO22253. Do any of you guys know what tractor this may have been made for?? Thanks
gene bender
04-17-2007 04:15:58
 Re: What tractor does tihs plow fit?? in reply to old, 04-16-2007 11:41:52
Any other parts or just the beam with moldboard?
old
04-17-2007 11:09:50
 Re: What tractor does tihs plow fit?? in reply to gene bender, 04-17-2007 04:15:58
Towards the back theres a bar about 18 inch wide with 2 parts coming up about a foot or so to hook up some sort of lift set up on it.
Brad in TX
04-16-2007 18:17:51
..... and it"s for an A. :)
Brad in TX
04-16-2007 18:14:07
old, It's the main beam to an A-91 plow.
old
04-16-2007 18:15:40
 Re: What tractor does tihs plow fit?? in reply to Brad in TX, 04-16-2007 18:14:07
So then what tractor does that hook to?? An A maybe ???
georgeky
04-16-2007 14:41:18
Old I went and looked at the two old plows I have here and niether have the PO number on them. One is a plow for a C and the other is for a Super A. I think yours could be for a F-12 or 14 maybe. I do have a couple sets of trailing plows with a P0 number. The plow you have could also be for an A or B. Is it a one bottom plow?
old
04-16-2007 17:48:35
 Re: What tractor does tihs plow fit?? in reply to georgeky, 04-16-2007 14:41:18
Yep just a one bottom.
georgeky
04-16-2007 12:03:26
Old I don't have all my old plows at home to check numbers, but if you had a picture I may be able to help.
old
04-16-2007 14:18:52
 Re: What tractor does tihs plow fit?? in reply to georgeky, 04-16-2007 12:03:26
Ya don't have any at this time. The main beam has one hole where a pin would go at the front end of it. Then close to the back of the plow theres a cross bar with 2 holes about and inch around and spaced about 18 inch wide. That whole set up is about centered with the main beam. Don't know if that info helps or not. Also looks to be a 14 or 16 inch bottom
