HEAD ON FARMALL 140 HELP ;;;;;;;;;;;;;;;;;
COPPER KAT
04-16-2007 18:17:14
WHAT CAN I DO TO GET MORE POWER FROM A 140 FARMALL HEAD????? ??? THANKS..... ...
NawlensGator
04-17-2007 08:56:07
 Re: HEAD ON FARMALL 140 HELP ;;;;;;;;;;;;;;;;; in reply to COPPER KAT, 04-16-2007 18:17:14
The standard compression is a little less than 7 to 1 so there is room to shave the heads and gain some compression.
Adding a 40,000 volt coil (~$40) lets you open the gap from 0.025 to over 0.040 which increases power a little.
Other things not involving the heads include higher compressiion pistons, increasing the rpm's (govener), or increasing sleeve bore.
