Timing a Super C
Wheaty
04-17-2007 11:00:39
Ok folks, This is the same SC I posted about earlier with the head gasket issue. I was able to maintain the timing of the engine (some how) from when I first tore it down. It stats right up, doesn't miss a lick, the valves are all adjusted as close as i can get them (used a feeler guage at .014 hot) according to the IT manual. My qiestion is, the book say's that the timing mark should allign with a mark on the clutch housing cover.. What exactly does this mark resemble?? There are no signs of anything broke off, but only a crease that was stamped into the cover from the factory. I is directly in the center of the housing, right below the flywheel and it's not very long. The book picture is kind of confusing as to where or what it looks like. Any who, if I throw a timing light on it, it seems to fire when the mark is aboput an inch to the left of the mark if you are looking up through the hand hole in the clutch housing. Should I line that mark up th where it fires right on the stamped crease in the cover?? -- sorry for the novel, but description is everything if you don't have a picture:)
Wheaty
04-18-2007 06:41:59
 Re: Timing a Super C in reply to Wheaty, 04-17-2007 11:00:39
Excellent guys. Thanks a bunch for the input:)
I figured kind of the same thing.. These weren't built to be race cars..Lol If she starts right up from being cold, it has to be darned near where it needs to be. I will give her a little more time on her break in, and check it again. My dad said the same thing, he said they pretty much set them by ear:) he and my Grand dad have worked on a few 4 cyl gassers as well:).. Some times I get a little too picky..:)
Hugh MacKay
04-18-2007 14:51:11
 Re: Timing a Super C in reply to Wheaty, 04-18-2007 06:41:59
Wheaty: These letter series Farmalls were designed for owner-operator maintenence. Kind of a shame in some respects. You buy a new tractor today and even if it hickups, you have to call on a 6 million dollar man with a computer to fix it.
About three weeks ago I spent an hour in a loaded plane on a tar mack, here in Ontario. folks were starting to ask what was wrong, why weren't we taking off? Finally the pilot came on the public address, told us that Boeing were doing a tuneup via computer from Washington State. Makes one think about the tractor of the future.
Hugh MacKay
04-18-2007 03:00:37
Wheaty: You obviously have the timing right and are close on timing advance as the tractor starts right up. Forget about those timing marks, and set it by ear with engine running at a brisk idle. Those 4 cylinder Farmall are very good at telling when it's right on. You may not get it right the first time, but someday your going to work the tractor 3-4 hours, take the wrench with you.
I'm 65 years old, encountered my first 4 cylinder gas Farmall close to 55 years ago. Over the years I farmed with about a dozen different Farmall gassers. I've yet to see the timing marks on any of them. Listen to your tractor, it will talk to you.
A. Bohemian
04-17-2007 11:34:58
 Where's that 3-D Holographic Manual When You Need in reply to Wheaty, 04-17-2007 11:00:39
Quote: "The book picture is kind of confusing as to where or what it looks like."
Agreed. And how!
From you're description, you've found it, though. That little "crease" is it.
With the timing light, the motor is running, and you are checking the running timing. The mark on the flywheel should only match up with the mark on the housing when the timing is set statically (motor not running).
Full advance MEASURED AT THE FLYWHEEL can be had from table 2 on page 49. Note that the numbers given are for the DISTRIBUTOR and must be doubled (as outlined in the heading to the chart) for the flywheel.
