Adding a Remote on a Super A?
Mark (PA)
04-17-2007 15:07:26
Hello all, I am wondering if it is possible for me to add a hydraulic remote to my Super A. I don't know exactly how this works but have heard from a friend you might be able to buy some sort of "Block" (piece of metal!!!) that you can put in between the hydrualic lines that are controlled by the Touch Control system. IS this the case? Can anyone give me any further info. Have you tried it? or is this not possible. I would like to be able to control 1 hydraulic cylinder. To use to raise and lower an implement wheel for height adjustment. Thy hydraulic cylinder has pressure both ways. Thank you for any information.
georgeky
04-18-2007 09:14:15
 Re: Adding a Remote on a Super A? in reply to Mark (PA), 04-17-2007 15:07:26
I see the original remote valves on ebay from time to time. I have one on my C and it works great. The same valve that works the fast hitch from a Super C or 200 will also work on the Super A.
Nat 2
04-18-2007 07:25:16
It's called a "bypass block," and a fellow from over near Buffalo, NY is making them and selling them on Ebay for reasonable prices.
The block bolts in between the hydraulic lines and the touch control block under the gas tank. You then connect hoses to the block, then connect the hoses to a generic "open center" hydraulic valve. Connect the work ports from your new hydraulic valve to the cylinder, and viola!
Bongo
04-17-2007 18:18:48
Here is a link to a by-pass valve on ebay now that is put between the hydraulic lines and the touch control unit. Then you need a new valve for the remotes and associated hoses.
I have one on my super C that feeds a two spool valve and also have this to install on my SuperA.
http://cgi.ebay.com/Hydraulic-By-pass-block-for-Farmall-Super-A-C-Super-C_W0QQitemZ300102136449QQihZ020QQcategoryZ63967QQrdZ1QQcmdZViewItem
Wardner
04-17-2007 15:28:54
Yes, it is possible. The newly mfgd kits are available on eBay.
I bought a slightly different block from my IH dealer 30 years ago to run a dump trailer. I pulled it with my Cub.
