Farmall 200 touch a matic
Don Anderson
04-18-2007 07:49:29
First, I want to thank all who have given me advice on this tractor. I am now trying to get the touch a matic figured out. Beside the two depth levers, there is a lever to the right used for raising and lowering the belly mower on the tractor. To me if sounds like the pump is laboring even with this lever in the neutral position. I drained the oil in the system and cleaned the filter. Does anyone have any suggestions on operating the system or what I am doing wrong?
george ky
04-18-2007 08:01:36
 Re: Farmall 200 touch a matic in reply to Don Anderson, 04-18-2007 07:49:29
It sounds like the unit itself needs adjusting. Do you have a manual? It is adjusted on the side of the unit. There are allen head plugs that you can see on each side of the unit. You will need the manual and likely a gauge to do this.
Don Anderson
04-18-2007 09:42:49
 Re: Farmall 200 touch a matic in reply to george ky, 04-18-2007 08:01:36
I have the original manual for it, but do not remember the instructions being very detailed. Will take another look tonight.
georgeky
04-18-2007 13:47:22
 Re: Farmall 200 touch a matic in reply to Don Anderson, 04-18-2007 09:42:49
Don get you an IT manual, number is IH 201 or a Blue Ribbon service manual. They both have a detailed procedure for the adjustments.
skin
04-22-2007 14:41:09
  Farmall 200 in reply to georgeky, 04-18-2007 13:47:22
I am trying to find out how to hookup a loader I bought on a sale so I can use it and the 2 point at the same time. I can"t figure out how to hookup the hydralics. Does anyone know how to hook a loader up on a 200 farmall.
