H psi
Pat-CT
04-19-2007 13:53:16
what is the average oil presure for an h i let it run for like 15 minutes and with a 30 psi it just stayed pined agains the other side of the gauge haha
also what type of oil should i put in the oilbath air cleaner
Steven@AZ
04-19-2007 14:12:26
 Re: H psi in reply to Pat-CT, 04-19-2007 13:53:16
The H, M, up through the 450 were all designed with a 75 psi relief valve for the oil pump.
My rebuilt H will run 70 psi all day long with Mobil Delvac 1 5w-40 in it at 1/2 to full throttle, at idle when warm it will come down to around 60 psi.
As long as you have over 20 psi at full throttle I wouldn't worry at all. I've seen many of them still running with 10 to 15 psi max.
chadd
04-19-2007 14:11:47
First off, you can put the same grade of oil in the air cleaner that you put in the crankcase.
Second off, I know an M should have between 45 to 70 psi of oil pressure. Your H has slightly lower oil pressure I believe, so I would guess somewhere around 35 to 60 or so. I am sure someone who owns an H can give you more info, mine are just ballpark numbers.
Pat-CT
04-19-2007 13:54:05
i meant to say with a 30 psi gauge
