pilot bearing replacement
boochie
04-19-2007 20:07:54
GUYS I THANK ALL OF YOU FOR HELP SO FAR SO PLEASE HELP AGAIN AND TAKE ME ALL THE WAY HOME
I HOPE THAT TOMORROW I WILL HAVE A PILOT "BEARING" SO HOW IS THE BEST WAY TO GET IT IN THE CRANK I HAVE ALREADY GREASED THE BORE AS U GUYS TOLD ME TO AND THE CLUTCHE SHAFT IS AS SMOOTH AS A BABY'S BUTT SO HOW IS THE BEST WAY TO GET IT IN THERE
WHEN I UT THE LAST BUSHING IN IT WAS PURE HELLO I PUT A OAK BLOCK ON IT AN PRESSED IT IN WITH A HUB PULLER/PUSHER WITH THE CRANK BOLTS ---SO ALL TIPS AND MORE OVER WHAT I DID WRONG ARE WELCOMED AND APPRECIATED
THANX IN ADVANCE BOOCHIE
BF8690
04-20-2007 08:47:30
 Re: pilot bearing replacement in reply to boochie, 04-19-2007 20:07:54
Dude, I don't care about caps or your typing ability so here goes. The Pilot Bearing goes into the fly wheel which is bolted onto the crank. Find a socket the will easily fit into the hole for the pilot bearing and only contact the pilot bearing on the outer race. Then gently pound it in. I prefer to do that with the fly wheel off but that will make you have to split the tractor, so just be gentle while pounding it in.
Denny ('60 Lo-Boy)
04-20-2007 19:44:49
 Re: pilot bearing replacement in reply to BF8690, 04-20-2007 08:47:30
In my tractor the pilot bearing goes in the end of the crank and the flywheel bolts to the crank.
Nat 2
04-20-2007 05:52:22
Okay, first off lose the all caps. Nobody likes a shouter. Second off, at least make some effort to communicate effectively. I'm not asking for perfect King's English, but a little effort would go a long way. Nobody has responded because we don't understand what you're trying to ask.
When I replace pilot bearings, I use a large socket that matches the outer edge of the bearing, and gently tap it in with a hammer, being careful to drive it straight. It's very easy to do.
rumplestiltskin
04-23-2007 11:50:21
 Re: pilot bearing replacement in reply to Nat 2, 04-20-2007 05:52:22
Nat 2’s approach has worked well for me.
I also like to insert an extension into the socket. The longer the better (up to about 8 to 10 inches). This makes any misalignment easier to spot and helps me drive the bearing straighter.
Mark W. in MI
