M hydraulics???????
Patrick Martin
04-20-2007 18:44:56
Does an M have hydraulics? Are they just a drawbar hookup or are there supposed to be lifts????
I'm looking at a restorable pair right now and noticed that there aren't any arms on the back or any sort of lift?????
Tractor Tom
04-21-2007 06:44:43
 Re: M hydraulics??????? in reply to Patrick Martin, 04-20-2007 18:44:56
M's (as well as H's) had a "Lift-All" as an available option (AKA belly pump). They were located in the center section of the cast frame, between the clutch and the trans. As CNKS said, it worked only when it was engaged and the clutch was released. It should be easy to spot, even if it isn't being used, typically there are several pipe fittings protruding from both sides of the tractor. As CNKS said, there are some aftermarket 3-point hitch makers, such as Worksaver. Adding a hitch is a very popular modification. Search the archives for other info on hydraulics, good luck.
Don L C
04-21-2007 19:20:29
 Re: M hydraulics??????? in reply to Tractor Tom, 04-21-2007 06:44:43
There is a bout a 5/16" rod that comes back in reach of the driver on the right side under the head light..... .it has a down bend and bent into a small 1" circle...thats the handle. slides back and forth.....
CNKS
04-20-2007 19:02:02
Mounted equipment was either underneath the tractor, mounted on the rear axle, or in the case of cultivators, both. Hydraulic cylinders were attached to the equipment, and in some cases to arms attached to the casting below the belly pump. For rear mounted implements rods ran from the front (either or both sides of the clutch/belly pump housing) cylinders to the implement in the rear. There is no formal "hitch".
Patrick Martin
04-20-2007 19:04:42
 Re: M hydraulics??????? in reply to CNKS, 04-20-2007 19:02:02
Would you think I would be going wrong by picking up 2 M's for $600?
How difficult would it be to add a 3pt to the rear?
Hayfarmer
04-20-2007 19:34:38
 Re: M hydraulics??????? in reply to Patrick Martin, 04-20-2007 19:04:42
I don't think you could go wrong if you can get 2 Ms for $600. Hopefully would be able to build at least one good one. Standard M hydraulics are not live, that is you have to have clutch out to work. Also are usually one way for one way cylinder. You can add an aftermarket 3 point fairly easily, not necessarily cheaply though. Severl manufactures make different units.
Patrick Martin
04-21-2007 00:59:52
 Re: M hydraulics??????? in reply to Hayfarmer, 04-20-2007 19:34:38
So there are factory hydraulics on an M?????
I've looked and all I have been able to find are aftermarket pumps? Where is the pump on an M? I don't see any lines or hoses running from the engine to the rear so I assume that it's either in a housing or the pump is in the transmission.
I take it that these were drawbar only tractors, correct?
CNKS
04-21-2007 12:28:39
 Re: M hydraulics??????? in reply to Patrick Martin, 04-21-2007 00:59:52
Hydraulics were an option. The belly pump is between the clutch and transmission. There are two outlets on the left side of the clutch housing/torque tube and one on the right. Plows, cultivators, listers, planters, etc could be mounted on the tractor. Thus they are not drawbar only tractors. In those days, the mounted equipment was provincial, that is an implement for one make of tractor did not fit another, in some cases implements of the same make did not interchange between models of the same make, unlike today's 3 point hitches. With some modification, the live pumps from the Super M--up will fit an M. Rebuilt belly pumps are available. A live pump from M&W will also fit, but is hard to come by. The W series, W4,W6/WD6, and W9/WD9 were drawbar only tractors.
Patrick Martin
04-21-2007 15:34:46
 Re: M hydraulics??????? in reply to CNKS, 04-21-2007 12:28:39
Thaks guys!!!!! I will be getting these if they haven't already sold I guess!!! :)
