C264 rod installation
turbos10
04-21-2007 16:34:17
Guys,
I could check with trial by fire, but which direction are the rods installed on the crank? bolts toward or away from cam?
Thanks,
Chris
georgeky
04-21-2007 17:03:35
 Re: C264 rod installation in reply to turbos10, 04-21-2007 16:34:17
On each rod and cap is a number 1 thru 4 intsall with numbered side towards the cam. Torque to 60 lbs.
turbos10
04-21-2007 16:35:43
 Re: C263 rod installation in reply to turbos10, 04-21-2007 16:34:17
M by the way if it matters...and I think that is C263..
El Toro
04-21-2007 17:34:33
 Re: C263 rod installation in reply to turbos10, 04-21-2007 16:35:43
The M is 248cid. Hal
PS: Super M 264cid
turbos10
04-22-2007 10:02:12
 Re: C263 rod installation in reply to El Toro, 04-21-2007 17:34:33
Thanks for the help, guys. I am not real good with the numbers. This is actually a 4.25 bore pulling engine so it is around 298cid.
El Toro
04-22-2007 10:09:52
 Re: C263 rod installation in reply to turbos10, 04-22-2007 10:02:12
third party image
That should make it snort. I would like to hook it to this vehicle for a drawbar pull test. Hal
turbos10
04-22-2007 19:21:35
 Re: C263 rod installation in reply to El Toro, 04-22-2007 10:09:52
Hehe...that would be a bit tough to get rolling I suppose. I would definately get to test out the new 2 disc slipper.
