international 584 pto
damented39
04-22-2007 08:04:35
i purchased my 584 , every thing works great, except the pto , i discovered that the pto quits working when under a load,, my hydro level is full What do i check now ,,, help.. damented39
richard in nz
04-23-2007 04:34:52
 Re: international 584 pto in reply to damented39, 04-22-2007 08:04:35
If oil pressure ok then its worn out. It comes out of the round access plate behind the right back wheel, after draining oil, pulling the top stub shaft out the back, and driving out a roll pin inside, should be in your lap in 3/4 of an hour, they aint difficult!
Bernard le mécano
04-22-2007 16:56:08
Hi, check the oil pressure. It have a small T with a cap, in front of the left rear axle. Bernard le mécano
