1948 Farmall Questions
Roger Kansas
04-22-2007 10:19:21
I have posted a picture of my tractor on the gallery. There is still a lot of work to be done on it . Can anyone tell me about the two holes on the side of the hood and how were they covered. I would also like to know about Decals for this tractor they are all gone.
Dave BN
04-22-2007 14:27:41
 Re: 1948 Farmall Questions in reply to Roger Kansas, 04-22-2007 10:19:21
I got my "letter Series Origionality Guide" at Barnes and Noble. Great Book. Dave
James Williams
04-22-2007 11:35:56
Roger,If you look through the holes there shiuld be 2 grease holes
Roger Kansas
04-22-2007 12:38:48
 Re: 1948 Farmall Questions in reply to James Williams, 04-22-2007 11:35:56
Thanks James Lube for the front and back of the generator correct. Were these holes just left open ar were they covered someway.
Bigdog
04-22-2007 15:06:36
 Re: 1948 Farmall Questions in reply to Roger Kansas, 04-22-2007 12:38:48
They are just left open.
georgeky
04-22-2007 10:33:55
Roger, I don't know what the holes are for. I think someone has cut those for some reason. My Cub does not have them nor have I seen any others with them. Decals can be ordered here on yesterdays tractor site I believe, if not you can get them at TSC and other farm stores or any Case IH dealor. You may want to find a picture of one to reference with the placement of decals.
BF8690
04-22-2007 11:32:50
 Re: 1948 Farmall Questions in reply to georgeky, 04-22-2007 10:33:55
The Farmall Letter Series book by Guy Fay and Andy Kraushaar has an excellent decal placement chart. That book is worth the read also, it tells you everything you ever wanted to know about each individual letter series tractor.
Roger Kansas
04-22-2007 12:34:06
 Re: 1948 Farmall Questions in reply to BF8690, 04-22-2007 11:32:50
Thanks can the book be found at book stores or do I have to order it? If someone cut them they did an excellent job the one on the rear has a little nipple at the top of it.
BF8690
04-22-2007 13:58:24
 Re: 1948 Farmall Questions in reply to Roger Kansas, 04-22-2007 12:34:06
I'm not sure but any book store should be able to order it if they don't have it. You might want to check on-line. You could probably get it quicker that way.
