65' Lo-Boy clutch
Josh in Maine
04-22-2007 16:10:42
I'm about to start taking my 65' Lo-boy apart to replace the clutch. I've got a copy of the shop manual & I have replaced the clutch on my 51' Cub (years ago), but, I'm looking for any advise, or "tricks" before I split the tractor. A friend was telling me that my clutch may likely need adjusting? is this true? How do I adjust the clutch on a 65' Lob-boy? Thanks for any help! Josh
Nat 2
04-23-2007 06:36:56
 Re: 65' Lo-Boy clutch in reply to Josh in Maine, 04-22-2007 16:10:42
You've done it before. This will be the same, except 8" closer to the ground. About the only thing different between your '51 and the '65 is the shape of the hood as far as working on the two. Engine, tranny, clutch are all the same.
You MAY need to adjust the three fingers on the pressure plate. They used to come preadjusted, but now they don't necessarily come that way.
