What the heck is this on my tractor??? PICS
Patrick Martin
04-22-2007 17:01:08
OK, I've been looking at these things/features for several months and have been trying to find out what their purposes are.
First pic: What is this on my wheel? At first I thought it was an extension for a dual wheel setup but it looks like it's not now since nothing lines up with other wheels that I have.
third party image
Second pic is of a sleeve that protrudes from the inside of my final drive. At first I thought it was some part that had stripped itself loose and had begun to slide out but after removal of the housing I saw it had it's own felt seals and all so it seems like it's supposed to be sticking out. What the heck is this for?????
third party image
ShepFL
04-23-2007 08:05:31
 Re: What the heck is this on my tractor??? PICS in reply to Patrick Martin, 04-22-2007 17:01:08
Patrick -
To me it looks like home made gear drive for fertilizer distributor. I have a John Blue fertilizer distributor that has gear larger than that. Runs off the rear tires on my AC D10.
Took me forever to find a manual for it but it is unique and I have not seen another in my area (N. FL/S. GA).
Mike CA
04-22-2007 18:53:18
The first pic is obvious. It's a saw blade. You pull alongside other farmers in your area and slash their tires, ala James Bond. Thereby ending their farming season, where you get to reap the rewards from higher prices due lowered supply. Simple and brilliant!
The second pic I have no idea.
Patrick Martin
04-22-2007 19:03:32
 Re: What the heck is this on my tractor??? PICS in reply to Mike CA, 04-22-2007 18:53:18
HAHAAAA!!!!! You know what Mike, I'll have to admit that I tried that already!!!! :) Took down some old fenceposts, that's how I bent it a little! LOL!
gbs
04-22-2007 18:39:58
as one of the earlier replies stated , the one behind the left side is where the fertlizer ,planter etc. drive sprocket mounts. the one on the right is a home made sprocket assy.for most likely a johnblue fertlizer dist.which used this type of drive.
IHC-Farmall
04-22-2007 17:56:53
I seen on your pic's that your top pic says X and the bottom one says Z. If everything else is Z then it is a 54 if X then it is a 52 from the pic's it looks like you got a pieced to gether tractor.
Fred Mills
04-22-2007 17:25:46
On our super A the inside sleeve was the drive for a sprocket that turned the fertilizer distributer and planter. The sprocket on the wheel appears to have the same type function.
A sprocket fit on the sleeve and a chain ran to a sprocket on the distributer.
Hope this helps.
Patrick Martin
04-22-2007 17:02:32
By the way, this is on a Farmall 100.
Andrew Z
04-22-2007 17:14:26
 Re: What the heck is this on my tractor??? PICS in reply to Patrick Martin, 04-22-2007 17:02:32
maybe for some type of planter or a sod cutter? I know that a few implemts can be run off the final drives.
Andrew
Patrick Martin
04-22-2007 18:08:24
 Re: What the heck is this on my tractor??? PICS in reply to Andrew Z , 04-22-2007 17:14:26
IHC-Farmall,
Everything else for the most part is a Z. I have that heavy wheel and one other part that has the other letter.
Patrick Martin
04-22-2007 18:11:07
 Re: What the heck is this on my tractor??? PICS in reply to Patrick Martin, 04-22-2007 18:08:24
Fred Mills,
Ahhhhh ! So it is supposed to be here! Would you happen to have any pics of your setup Fred?
Patrick Martin
04-22-2007 18:12:10
 Re: What the heck is this on my tractor??? PICS in reply to Patrick Martin, 04-22-2007 18:11:07
Andrew Z ,
By that do you mean from the inside or from the outside (wheel side)?
