H and 300 oil pump
jr300
04-22-2007 18:43:24
is the oil pump for an h the same as the one in a 300? I have a parts book for an h but not a 300 thanks!
Dave S.
04-22-2007 20:37:25
 Re: H and 300 oil pump in reply to jr300, 04-22-2007 18:43:24
I overhauled a 300 engine to put in my H and the gear on the oil pump was bad. I got one out of an H took it apart, cleaned it up, had the bottom cover surfaced, installed it and it works fine. 75 psi hot at high idle and 45 psi at low idle after pulling a plow for 3 hrs. Dave
jr300
04-22-2007 20:55:40
 Re: H and 300 oil pump in reply to Dave S., 04-22-2007 20:37:25
Dave, What does it take to get it surfaced? I have not been in one so I am unsure what to do or how involved it is...Thanks, Jason
Dave S.
04-23-2007 02:54:40
 Re: H and 300 oil pump in reply to jr300, 04-22-2007 20:55:40
Take out the cotter key that holds the oil pickup on and the 4 bolts for the cap. The cap will have pressure from the relief valve spring against it. Mine had wear from the gears running against it. I took it to the machine shop and they ran it over a surface grinder they use on cyl heads and never charged anything. Be sure to lube it up good with motor oil before putting it back together. Dave
jr300
04-22-2007 20:20:39
i guess they are the same! thanks for the web site....
CNKS
04-22-2007 19:22:55
You can look up the part number on www.caseih.com.
