Order Farmall Cub Parts Online
1948 Farmall Cub Front Pulley removal
Mark JF
04-23-2007 08:26:11
I am replacing the front crank seal and need to remove pulley. What is the best way to remove. Can you add heat to the pulley?
Thanks,
Mark
Mark JF
04-23-2007 09:31:22
 Re: 1948 Farmall Cub Front Pulley removal in reply to Mark JF, 04-23-2007 08:26:11
Very nice!!! I can do that.
Thanks,
Mark
Bigdog
04-23-2007 14:22:29
 Re: 1948 Farmall Cub Front Pulley removal in reply to Mark JF, 04-23-2007 09:31:22
Make sure you do not pull against the pulley flanges. They will not take the strain necessary for removal of the pulley without breaking. Use a backing plate that contacts further down onto the pulley back. A bearing separator works well.
El Toro
04-23-2007 10:18:40
You can get the 3/4 allthread at Home Depot. Get a 36" piece and cut it into 2 equal lengths. They have the washers and nuts too. Hal
El Toro
04-23-2007 09:00:26
third party image
You probably need to have a puller made or make it yourself like this one BigDog made for his Cub
using a bottle hydraulic jack or ram. Hal
