784
784
04-23-2007 09:51:31
How good is the 784. And vs the 686/666/656
gmd
04-23-2007 16:07:27
 Re: 784 in reply to 784, 04-23-2007 09:51:31
Theyre all great tractors, but Theyre in sort of a different league. I think the horsepower is similar, but the 784 will have a 4 cyl diesel and the others will have a 6 cyl gas or diesel. That will make a Huge difference even though they are rated the same. A 6 will outwork a 4 cylinder every time. Fuel comsumption will be a little better with the 4 I think. The 656 666 686 is a much bigger sized tractor with a variety of transmissions. You could get hydros on the 656. Also the price difference will be pretty big. A decent 656 diesel can go for 4-5k whereas a decent 784 can go for 7 up to 12k. The 784 is a much better loader and chore tractor, especially if it has the shuttle shift. Now they did actually make a utility version of the 656. Essentially in the same class as the 784 but with the 6 cyl motor. Not as many nice ammenities but a good tractor. I know its a lot of things to look at but hope this helps.
