Help!, one more Farmall 300u question
truckmaster100
04-23-2007 15:05:08
On the hydraulic block i have for the power steering it has a small fitting and a larger one, i assume the small one is the pressure line, what is the other one for, can i plug it ?
I"m installing power steering on a 300u
Don Benson
04-23-2007 15:35:24
 Re: Help!, one more Farmall 300u question in reply to truckmaster100, 04-23-2007 15:05:08
small one on the (under the seat)block or tank 1/8 " is a by pass the 1/4 " is high pressure and the 3/8 is the return line.
TDK
04-23-2007 20:43:24
 Re: Help!, one more Farmall 300u question in reply to Don Benson, 04-23-2007 15:35:24
The small one on the regulator valve is the pressure line. The large one is plugged if you have a single hyd. valve. If you have 2 or 3 valves then let us know.
truckmaster100
04-24-2007 19:29:40
 Re: Help!, one more Farmall 300u question in reply to TDK, 04-23-2007 20:43:24
single valve with lines to draw bar and lines for aux equipment, i not currently using them
TDK
04-24-2007 20:54:46
 Re: Help!, one more Farmall 300u question in reply to truckmaster100, 04-24-2007 19:29:40
Are you saying that the aux. lines are operated from the same hyd. valve ? If this is the case then you can plug the large hole in regulator valve.
