460 Clutch question - not disengaging
Kevin LA-CA
04-24-2007 18:58:37
I am in the process of obtaining a service manual to perform a split to repair the clutch issue.
I have learned that the clutch doesn't disengage & "squeals" when trying.
Is this a 1) bad throwout bearing, 2) poor linkage adjustment or 3) failed pressure plate fingers? (I am guessing 1)
I assume that 1 & 3 require a split.
Any thoughts or experiences?
kevin
chadd
04-25-2007 08:00:12
 Re: 460 Clutch question - not disengaging in reply to Kevin LA-CA, 04-24-2007 18:58:37
Sounds like the classic symptoms of a throwout bearing failure. You can check before getting into the split by removing the inspection cover and looking at or moving the bearing. If it has any freeplay or movement to it, it is junk.
Fancy Farm
04-24-2007 19:01:49
Last one I had was a clutch plate pressure plate was OK
Got one doint the same thing on a little A I just finished painting.
Fancy Farm
04-24-2007 19:01:37
