anyone have a 72 mower on there Farmall A
Chad from Michi
04-25-2007 09:34:29
Does anyone have a 72" woods on there famrall A?
I know the woods L59 mower will work good on the A my dad has one. But I want to know if I put a 72" woods on my A will it rob it of to much power
like the difference from a 42" and a 60" on the Cub?
I just don't want to waste my time. I have a 60" on its way and I can get the 72 deck for $100.00
what do you think?
gene bender
04-26-2007 05:03:18
 Re: anyone have a 72 mower on there Farmall A in reply to Chad from Michigan, 04-25-2007 09:34:29
Depends on your mowing area but you have plenty of power to run the 6ft.
dave guest
04-25-2007 20:27:32
Have cub with 60" seems like a little hard work. Have A with 60" piece of cake.
dave guest
04-25-2007 20:27:21
Hugh MacKay
04-25-2007 19:07:10
Chad: The down side I see with the 72" mower is uneven ground. Fine if your ground is perfectly level and flat. I notice a couple of 72" mowers very near me, and you can see where they have been scalping the sod. I have a 60" and have a few rough areas. Very noticable difference how bad the extra 12" causes this. When that starts happening the mower soon gets dull, and dull mowers take a lot of extra power.
I notice this if I strike sod with my mower and take the sharp edge off, doesn't seem to bother SA very much on power, but you soon notice the belt and pullies warm up. While the blades are nice and sharp, I hardly notice the belt and pulley heat. Also, when blades are sharp, I can head into heavy grass a foot high.
jeramy from mi
04-25-2007 18:13:49
i just bought a international 184 with a 60 in mower it works great but someone put 2 v-belt pullies on the back and the belt is twisted to much and i think im loosing so power due to this
VAJerry
04-25-2007 17:50:58
I have a 6' under my SA. Handles it with no problem.
NawlensGator
04-25-2007 12:46:50
I use a 72" woods finish mower on the back of an IH 140 without problem. Been using it for almost 25 yrs now.
Started out as a RM 500 with 60" cut till the deck rusted out. Made a 72" deck out of 304 SSt, galvanized the gear box, and made the belt/pulley cover plates out of 316 SSt. Used the original spindals/pulleys with RM 660 blades to get 72" width. Course my blade tip speed is a little higher than stock, but cuts great in 2nd gear (& 3rd) with the 140's horse power in the low 20's. Oh, and I haven't had any rust problems for the last 15 yrs or so.
scotty
04-25-2007 11:41:36
Afternoon Chad, I think thats a bit much to ask of the A. Rule of thumb is 5 hp for every 1 ft of cut. So you would need a minumum of 25 to 30 hp for that mower. The A and Super A work great with a 5ft cut, but 6 ft would only work if on a flat with grass thats not too high IMO.
scotty
Chad from Michigan
04-25-2007 11:58:41
 Re: anyone have a 72 mower on there Farmall A in reply to scotty, 04-25-2007 11:41:36
Yes I don't want to get into the same problems I had with the cubs! I love my cubs but little under power for the 5' woods if the grass isn't kept up!
