IH trouble shooting?
navy seabee
04-25-2007 13:45:55
I am about to pull my hair out! I have just aquired a IH 2424, it runs good for a while but after i start puting a load on it and it gets warmed up it will shut down and not start again for about an hour, after it cools down it will start and run a while longer(aprox 20 min)then shut down again, when it shuts down it does so like turning the key off. when it shuts down it still has good spark. Fuel seems to be ok going to the carb but im not sure if it is going thru it, there is some kind of a electric float on the carb and i wonder if it is getting hot and shuting down the fuel? If anyone has any suggestions i could use to help trouble shoot this i am "all ears" Thanks, Seabee!
Owen Aaland
04-26-2007 03:40:55
 Re: IH trouble shooting? in reply to navy seabee, 04-25-2007 13:45:55
My guess would be the fuel shut off solenoid. If you hold your hand on it you should be able to feel the fuel shut off solenoid click when you switch it on and off.
If the 2424 has an electric fuel pump like the 2444 make sure that the pump is still running when ithe engine stops on you. When it fails it usually does not stop the engine as fast as the fuel solenoid does.
Will Sick
04-25-2007 19:45:10
I would suspect the coil. When it dies check for spark.
sd pete
04-25-2007 18:24:18
My son is a Seabee. Right now he is in Gulfport Ms. Good luck on the IH. Do those carb's have the screen on the inlet like the old M's?
Herb In Texas
04-25-2007 16:43:47
Don't know what your tractor troubles may be, but the fuel solinoid deallie sounds good to me.
I am replying to thank you for your service to us, I mean U.S. Most folks today don't Know or even care that you guys put it on the line for U.S. I do. and for serving and believing in the U.S. you have my eternal thanks and gratitude.
Herb
A. Bohemian
04-25-2007 18:26:09
 Can Do! in reply to Herb In Texas, 04-25-2007 16:43:47
Well done, sailor!
As everyone knows, there's the right way, the wrong way, and the Navy way. You guys do things the RIGHT way.
navy seabee
04-25-2007 18:01:31
 Re: IH trouble shooting? in reply to Herb In Texas, 04-25-2007 16:43:47
Thank you Herb, God Bless You!
navy seabee
04-26-2007 16:04:55
 Re: IH trouble shooting? in reply to navy seabee, 04-25-2007 18:01:31
Another question, The pto on this tractor turns all the time, is there a lever thats turns it off? and what does the term "live pto" mean?
Sorry guys, im not a farmer...i just love tractors!
Owen Aaland
04-26-2007 17:24:35
 Re: IH trouble shooting? in reply to navy seabee, 04-26-2007 16:04:55
The PTO control lever is located just in front of the left brake housing. To the rear is engaged, forward is disengaged. When forward it tends to be in the way of your left leg.
Live PTO refers to being able to have the PTO running while disengaging the ground speed of the transmission. This is accomplished by using a two stage clutch. Push the clutch part way down and it releases the transmission input shaft. All the way down also releases the PTO drive.
Independent PTO refers to having separate clutch controls for the PTO and transmission. An IPTO can be engaged without stopping the transmission.
navy seabee
04-27-2007 04:58:00
 Re: IH trouble shooting? in reply to Owen Aaland, 04-26-2007 17:24:35
"when forward it tends to be in the way of your left leg"....Oh, that lever,yep it is much easier when it is in the rearward possition....lol, thank you very much,this web site is awesome! Curtis
ElliotL
04-25-2007 15:56:31
Check for proper spark when it shutsdown. This is a symptom of ignition coil issues.
chadd
04-25-2007 14:51:20
There are two ways to check the fuel shut off solenoid under the carb. After it dies, quickly unscrew it from the bottom of the carb, lay it against a bare patch of metal or something with a ground, and then turn the key on. If it doesn't move inward quickly, it is dead. Also, with our 2500, when you turn the key to the run position, you can hear a click when the solenoid energizes. If you hear it when it is cold, but then don't hear it after it stalls, that would seem to make it the culprit.
