300 Row Crop oil pressure revisited
jr300
04-25-2007 18:10:02
So I got a new gauge and the pressure at full power is around 60lbs. The tractor warms up and at idle will drop to 45 or so....looks like the engine is pretty good. Do you think I should check/rebuild the pump or let it go? Thanks for all the help!
Steven@AZ
04-25-2007 19:41:31
 Re: 300 Row Crop oil pressure revisited in reply to jr300, 04-25-2007 18:10:02
When it gets down to 20psi at full throttle, you can think about a rebuild... For now you have a near perfect oil pressure.
NDS
04-25-2007 18:21:30
Was not much better than that when it was new.
Andy Motteberg
04-25-2007 18:20:11
I'd just let it go. Andy.
