IH 6788 trans grinding
Harvesterguy
04-26-2007 15:44:05
I have been borrowing a nice 6788 2+2 from a neighbor and would like to fix several things before I return it as a thank you. Most of the problems are basic fixes of hydraulic leaks and gauges, however the transmission range shifter tends to grind when putting in gear. If the shifter does go in easily, it will pop out as soon as the clutch is disengaged. It acts like a truck when the clutch brake is slipping. Does a 6788 have a clutch brake? If so, can it be adjusted easily? Any advice would be greatly appreciated.
-Harvesterguy
Tyler Fortney
04-29-2007 09:38:49
 Re: IH 6788 trans grinding in reply to Harvesterguy, 04-26-2007 15:44:05
I have a 1969 1256 that did the same thing, well here's what I did I drained the transmission fluid out of it re-installed the gears and put new transmission fluid in it and it shifted perfectly. I'm not quite sure what your 6788 is doing but thought this would help
Jay IH man
04-27-2007 21:04:11
The 2+2 aka aligator series has a electo hyd trans brake that is activated 2 ways. First the trans range shifter has a switch a bottom of qaudrant that is activated when in neutral and the brake is activated when the clutch pedal is depressed aginst firewall depressing a switch. These units have very little or no grind if set corectly. Range poping out is due to worn arm on range cover (external) and if you look it will probably be loose on shaft. If range cover is to be removed there is a drop box on side of range trans. IH made a special tool to remove cover without taking this off and any older shop would have this.
K.B.-826
04-26-2007 18:57:22
I've never worked on one of those, but if I remember right, the transmission brake was hydraulic applied and controled by a electric solenoid. The brake itself is probably very similar if not identical to the one used in the 3088 series two wheel drives. I know that the parts on those are very expensive compared to the style used on the 06-86 series, but are much more reliable. Keep in mind that the range transmission is a collar shift and it is impossible to shift without grinding unless the tractor is at a dead stop, the engine is at low idle, and the clutch has been disengaged for at least three seconds. If it still grinds once these conditions have been met, then you go looking for a trans brake problem. On the popping out of gear problem, thats a classic case of failed detent parts underneath the range trans cover. If these 2+2's are anything like the two wheel drive 86 and 88 series, it wouln't be a walk in the park to repair. Cab floor and seat need to be removed, unhook shift linkages, drain a few gallons of oil and remove the cover from the left side of the range trans, block the park lock assembley in the unlocked (up) position, remove the range trans cover while a helper works through the removed cover on the left side and catches the reverse shift fork and makes sure it's woodruff key does not get lost.
the tractor vet
04-26-2007 18:39:02
Yes it does have a transmission brake but you have to go thru setting the clutch free travel then the trans brake then the dump valve . Off the top of my head i can not remember the free travel on that tractor and i can not even get into my books as they are in my Ranger and it is setting broke down out at a buddys farm . As far as the jumping out of gear this sounds like the roller in the shift linkage has broken and this part is down under the range shifter cover not easy to get to ya have to darn near stand on your head and work thru the floor plate in the cab also having the range cover removal tool is a BIG help . even after ya get everything set correctly the gears do not stop the moment ya shove the clutch down ya have to give it a couple seconds .
JayWalt
04-26-2007 18:17:31
i dont know about you but If I lent my tractor to someone and they started wrenching on it I'd be a little ticked off. Maybe I'm just over protective, but I would consider asking the guy if It's alright if you fix a few things as a thank you instead of doing it without permission. I say this because some people like things done a certain way, like me, hehe.
It sure is a nice gesture and I'm not trying to discourage you by any means. Obviously he trusts you enough to loan it to you.
the tractor vet
04-26-2007 19:13:36
 Re: IH 6788 trans grinding in reply to JayWalt, 04-26-2007 18:17:31
Then how come when i have to BARROW a tractor , backhoe, dozer i have to fix it BEFORE I USE IT????? And when ya take it back and say something to the fact that By the way i had to fix this or that and owner says Oh yea i forgot to tell ya about that and boy i am glad ya did . Barrowed a 750 John Deere dozer off one of my buddys once had to take my semi tractor 65 miles one way to get the dozer and lowboy drive back 65 miles stop off and feed it 125 gallon go juice get to the farm and start pushen and all of a sudden i see this trail of RED OIL on the ground , this is not good probable that darn O/Ring that i a real pain in the donkey to change and it is Always on the right hydo motor . After taken a bath in oil only to find out that that is not the problem the whole hydro motor has come loose . To fix one must pull the FUEL TANK that is full remove two D 8 batterys pull the floor boards the seat and seat support then work upside down . 12 hours of work one 7 dollar O/Ring two hundred dollars worth of J D hydo oil . And when i told him that i had to fix it he says oh yea i forgot to tell ya that needed done .
JayWalt
04-30-2007 06:06:00
 Re: IH 6788 trans grinding in reply to the tractor vet, 04-26-2007 19:13:36
I'm just saying getting permission is probably the best route imo.
IlliniJohn
04-26-2007 19:23:38
 Borrowing Tractors, Re: IH 6788 trans grinding in reply to the tractor vet, 04-26-2007 19:13:36
Tractor Vet - -for that kind of help, you sure need to borrow a couple of my tractors for a couple of weeks -- -in fact, I"d probably even deliver them to you to use - - and, er, you might need to just adjust jest a tad r two - - BUT, I wouldn"t mind waiting - -ya got plenty of barleypops in the fridge, right????
You"re a good man!!!
John
the tractor vet
04-26-2007 20:06:42
 Re: Borrowing Tractors, Re: IH 6788 trans grinding in reply to IlliniJohn, 04-26-2007 19:23:38
Ya just might as well send them over as with all this rain i can not go and get the last two sheets of drywall and i can't dance and it is to wet to plow. All of our stuff is ready to rock and roll.
