Order Farmall Cub Parts Online
Cub hydrulics
Bobby Whitlock
04-27-2007 05:06:13
I have a 47 Cub with lift. It is putting hyd. oil into the crankcase. What can I need to do to repair this problem?
El Toro
04-27-2007 06:09:43
 Re: Cub hydrulics in reply to Bobby Whitlock, 04-27-2007 05:06:13
third party image
Let me try that pump breakdown again. Hal
El Toro
04-27-2007 05:56:15
Your hydraulic pump is the culprit. The seal is probably worn and may have dried from age and has worn a groove into the shaft and will probably require installing a speedi-sleeve to cover the worn area. It will provide a new surface for the seal too. Here's a parts breakdown on the
pump for the C, Super A & Super C. It will give
an idea of what's involved. Hal
