Farmall 300 trans gear
MJF
04-27-2007 18:24:59
I need the gear thats on the top shaft and is the very first one. I think it's a double gear(please correct me if I'm wrong) I believe It's called the main drive gear. It's a rowcrop 300. Will any gears out of others fit like a 300 utility, H , or 350. Thanks a lot Mike
MJF
04-28-2007 19:50:05
 Re: Farmall 300 trans gear in reply to MJF, 04-27-2007 18:24:59
Nope this 300 doesn't have a torque or a live pto
georgeky
04-28-2007 23:17:43
 Re: Farmall 300 trans gear in reply to MJF, 04-28-2007 19:50:05
In that case I do not have the right gear. The only one I have is for one With TA.
georgeky
04-27-2007 21:44:04
Are you talking about the sun gear that comes out of the TA? Is gear number 66 in the IT manual. If so I have one or two. If tractor does not have TA it will be different from the one I have. I may have some others too. Send me an email.
