coil on c farmall
JBowles
04-28-2007 10:43:20
just put on new coil on ole c when i tried to start it it melted the ground cable offand dont seem to be firing whats wrong
Bob
04-28-2007 11:41:50
 Re: coil on c farmall in reply to JBowles, 04-28-2007 10:43:20
If you mean the battery ground cable melted, there may have simply been a corroded connection that got hot.
Cleaning things up and replacing the cable MAY solve that problem, then on to troubleshooting the ignition system.
Or, was it ANOTHER "ground" that melted?
CENTAUR
04-28-2007 11:13:29
GROUND CABLE?CENTAUR
JBowles
04-28-2007 14:34:46
 Re: coil on c farmall in reply to CENTAUR, 04-28-2007 11:13:29
yes it was the ground cable from the battery
