706 hyd
Bob ia
04-28-2007 18:16:48
what pressure are you running and can you use relief valve of higher setting. They have 2500 and 3000 but couldn,t tell my son if would fit. He has a westingdorf 21 loader and it wont tilt flat on ground or down pressure to raise front wheels. we checked outlets and all have 1450lbs. any ideas thanks
the tractor vet
04-28-2007 19:58:41
 Re: 706 hyd in reply to Bob ia, 04-28-2007 18:16:48
The system should have a 1750 stock releif and you can go up to the 2450 with out and adverse problems . It will not make it raise faster on the 12 GPm pump but it will lift more IF THE LOADER IS MADE TO HANDEL THAT PRESSURE . If ya want faster loader speed the ya must step up to the the 17 GPM pump.
bobia
04-29-2007 03:37:49
 Re: 706 hyd in reply to the tractor vet, 04-28-2007 19:58:41
Tractor vet are these adjustable valves like on 1030 case or are they preset. thanks
the tractor vet
04-29-2007 06:34:59
 Re: 706 hyd in reply to bobia, 04-29-2007 03:37:49
Preset and ain't never heard of anybody changen one . Just and R &R .
Sheepdog in NE
04-28-2007 19:50:11
I'd stay with what the book calls for. If you only have 1,450# psi the 2,500 one will make a world of difference. The bigger ones will fit but the system is made for what the parts books call for.
