H gen voltage
henryviiii
04-30-2007 06:15:24
What voltage should I have for the output of a H gen with the 3 brushes and a C/O and Mag. ign. The amp meter shows about 15-20 amps on H postion of the switch.
Thank You
Janicholson
04-30-2007 06:21:11
 Re: H gen voltage in reply to henryviiii, 04-30-2007 06:15:24
The voltage will be between 6.7 volts (if the battery is needing a charg) and 7.2 (if the battery is charged), and you are on H on the switch. The voltage floats some, and depends on the operator for adjustment with the H/L switch, and the third brush if needed (usually not) JimN
