clutche problems i think
will in texas
04-30-2007 14:23:27
my father has a mccormick farmall super mta that will start off pulling then you throttle it up the tractor will stop pulling and make a high pitche whinning sound
chadd
04-30-2007 14:36:25
 Re: clutche problems i think in reply to will in texas, 04-30-2007 14:23:27
Sounds like a clutch or a T/A problem. When was the last time the T/A and clutch were adjusted? (they should be adjusted together) If it is a clutch problem, either:
a)oil or grease on the linings
b)weak or broken release springs
c)maladjusted pedal free play, causing the throw out bearing to always contact the clutch fingers, keeping the clutch slightly disengaged.
You can try getting it readjusted (which will require a service manual, as the adjustments are crucial if there is a TA installed in it), but if the clutch has been slipping a lot, it will probably be pretty glazed, and will require replacement or some sort of roughing up.
