Dead cylinders #2 #3
Rudi52
04-30-2007 17:23:57
IH B414 gas, #2 and #3 cylinders dead- have gas, have spark, have good compression. Engine is only running on #1 and #4 cylinder, pull plug wires from the middle two cyl. and engine doesn't change a bit. Has new points; wires and plugs where changed a year ago, all cyls. at 120 lbs. compression, plenty of fuel from pump. tractor was running fine and then started cutting out, any ideas? Thanks!
Will Sick
04-30-2007 22:06:01
 Re: Dead cylinders #2 #3 in reply to Rudi52, 04-30-2007 17:23:57
Check your intake gasket on the manifold.It may be sucking air on those two.
georgeky
04-30-2007 18:38:08
Have you checked the plugs to see if they are fouled. The 2 and 3 are typicaly the two that foul first. Maybe she is burning a little rich. I wouldn't rule out the prankster either. I have old buddies that like to monkey around with wires sometimes.
georgeky
04-30-2007 18:36:52
old
04-30-2007 17:58:06
As Bob says and you might have the fireing order wrong. You also could have a bad distubutor cap and its cracked and shorting out there. Or you could also have bad plugs. Take the plugs from #1 and #4 and put them in to 2 and 3 and see what happens
IHC-Farmall
04-30-2007 17:57:32
I would check your firing order, could just be someone pulling a joke.
Bob
04-30-2007 17:30:08
I would assume you have the firing order correct???
