3 pt or Fast Hitch?????
Patrick Martin
05-02-2007 03:27:41
So what do you guys dig? Do you prefer a Fast Hitch or 3pt for everyday use?
Is it worth going the extra effort to convert everything over with Fast Hitch forks or to just go with a 3pt? Is stuff actually still available for the IH Fast Hitch sytem?
Just curious here, I'm actually thinking of going 100% fast hitch on one of my tractors.
Mike Van
05-02-2007 14:30:12
 Re: 3 pt or Fast Hitch????? in reply to Patrick Martin, 05-02-2007 03:27:41
Unless you have a barn full of fast hitch stuff, I'd say 3 pt. They haven't made a fast hitch implement since when?
Nat 2
05-02-2007 06:56:47
If you're talking about a factory fast hitch versus an AFTERMARKET 3pt, the fast hitch wins hands down.
The aftermarket 3pt hitch is very limited in usefulness, as in you can't use it with hard-pulling equipment that requires draft control, such as a land plow. It puts stresses on places that weren't designed to take those stresses, so you need to be careful. Items like mowers, back blades, bale spears, post hole diggers, etc. can be used, but don't expect to be able to plow.
John S-B
05-02-2007 07:49:14
 Re: 3 pt or Fast Hitch????? in reply to Nat 2, 05-02-2007 06:56:47
I plow with my M just fine with a three point hitch. It's a lot harder to find fast hitch implements than three point, I can use any brand.
georgeky
05-02-2007 05:33:41
Myself, I prefer the fast hitch. Most implements that are available are old used ones, and some can be a little hard to track down. There are some companies that do make things such as grader blades for them, but not many. I saw a brand new blade at a sale last year. It was yellow, but I don't know the brand. I do know that Bushhog use to make mounted mowers for the fast hitch. I do have some implements that are quite heavy,but work good. Two of my tractors have top link brackets and can use 3 poit implements on those as well as 2 point. I use my fast hitch stuff for every kind of farm work, but I already have lots of IH fast hitch implements.
bshannon
05-02-2007 05:15:57
We have an 806 with fast hitch. What we like about it is lifting an implement off the ground with the drawbar. Also we have fast hitch arms that go over the 3 point pins on an implement, so can pretty much use any 3 point machine on the fast hitch. But in reality I don't see any advantage and use the 3 point hitch tractors for the implements most of the time.
Allan In NE
05-02-2007 04:23:19
Pat,
The two point hitches outgrew themselves very early on because they were limited in the amount of weight that they could handle.
Not in the tractor hitch itself, but rather in the amount of reinforcement needed at the implement hitch.
Allan
Patrick Martin
05-02-2007 03:42:27
third party image
Great idea really..... ..... ....
Patrick Martin
05-02-2007 16:45:11
 Re: 3 pt or Fast Hitch????? in reply to Patrick Martin, 05-02-2007 03:42:27
Thanks guys!!!!
Well, I guess I'll fab up a 3pt for my 100 then:)
I'd like to find a Fast Hitch for one of my M's though.
georgeky
05-02-2007 23:23:56
 Re: 3 pt or Fast Hitch????? in reply to Patrick Martin, 05-02-2007 16:45:11
Unless one of your Ms is a Super MTA a fast hitch will be quite difficult to add. The rear end is not set up for these.
