Charge Indicaotr
Nifty 350
05-02-2007 06:53:16
I installed a reproduction charge indicator [has the IH logo and part number on the face plate]. After it ran the tip of the needle rests on the face plate and when I turn off the tractor it does not go back to 0. When I tap on it will go back. Thinking I had a bad gage I installed another new one and it does the same thing.
When I disconnected the first one, the needle is now off the face plate! Seems like it is getting magnetized. I have checked the wiring and know it is wired correctly.
Anyone have suggestions?
Andy Motteberg
05-02-2007 08:02:13
 Re: Charge Indicaotr in reply to Nifty 350, 05-02-2007 06:53:16
Is it wired correctly?
Bob M
05-02-2007 07:50:50
 Re: Charge Indicator in reply to Nifty 350, 05-02-2007 06:53:16
That’s an odd one! I think IH2444 below has it –you likely got a couple from a batch of defective ammeters.
Suggest purchasing another brand of ammeter, sticking it in and seeing what happens. (Get a cheapie from your neighborhood NAPA or whatever.) If the new one works OK then you know the repro gages you bought “have issues”.
IH2444
05-02-2007 07:26:24
Sounds like bad gauges to me, both same thing from same place ? Maybe all that batch or design is bad.
Nifty 350
05-02-2007 08:05:45
 Re: Charge Indicaotr in reply to IH2444, 05-02-2007 07:26:24
I bought the first at an antique tractor show. The second was from OEM Tractor Parts. It looks like they were made by the same company.
I have seen these gages on other tractors and the needle touches the plate.
