'39 Farmall H - ignition
Lance in Brenha
05-02-2007 07:45:57
The H I just bought is missing the magneto/distributor. Were H's available with either magneto or distributor in 1939? Or were they magneto only? Should I go back with a magneto or distributor? Thanks
SKK-Big Red Fan
05-02-2007 19:55:16
 Re: '39 Farmall H - ignition in reply to Lance in Brenham, TX, 05-02-2007 07:45:57
So any out there have one of the cables for sale?
randy hall
05-02-2007 12:32:03
the '39 tractors used an ih model h-4 magneto with a cable grounding switch.
gene bender
05-02-2007 17:31:48
 Re: '39 Farmall H - ignition in reply to randy hall, 05-02-2007 12:32:03
The early mags are the same as later ones the cable and slide sw will mount on any of the mags as they all have the holes drilled and tapped the cable sw was for the ones without a starter. if you need the cable sw i have one.
Brown Dirt Cowboy
05-02-2007 19:21:13
 Re: '39 Farmall H - ignition in reply to gene bender, 05-02-2007 17:31:48
Gene I went to the shop and looked and my mag has the slide I will need to find a cable for it. Thanks Tom
Brown Dirt Cowboy
05-02-2007 14:37:59
Randy are those early h-4 mags with the cable as hard to find as the '39 style seats? Tom
randy hall
05-02-2007 18:08:29
 Re: '39 Farmall H - ignition in reply to Brown Dirt Cowboy, 05-02-2007 14:37:59
like gene said the h-4 is an h-4, it is the pot metal piece that goes on the magneto with the slide in it that is kind of hard to find.
Steven@AZ
05-02-2007 08:25:08
Most likely came with a magneto, and that would be my choice regardless of what it came with. I love my magneto tractors because it doesn't matter if the battery is dead, I can still work!
farmallmagneto.com has good prices on rebuilt mags.
05-02-2007 09:54:52
 Re: '39 Farmall H - ignition in reply to Steven@AZ, 05-02-2007 08:25:08
Thanks
old
05-02-2007 08:15:18
Most likely came with a mag unless it was a special order with a dist. If you need a mag I have one but it needs points to get it up and working again. E-mial is open
Andy Motteberg
05-02-2007 07:57:49
Your 39 H originally used a magneto, you can still use a bistributor, but you need battery and hookup for the distributor. I recommend using a magneto. Andy.
