Farmall C identification
dave in NB
05-02-2007 14:24:12
Gentlemen
I am a long time reader first time poster. I recently bought a 1949 Farmall C, I have been reading all the postings on this forum and I must say I"ve had most of my questions answered already, but I have 2 additional questions. The numbers on my C are as follows. Model FC ser# is 35318. the engine Ser # is FCM 35726 G. My questions are 1. what does the M in FCM and G stand for. 2. Is this a 113 or 123 CID engine, I was told that the 123 could have been a substitution for the 113. is this true? Just want to know what i"ve got here before i start tearing into it.
wkfarmall
05-03-2007 05:00:19
 Re: Farmall C identification in reply to dave in NB, 05-02-2007 14:24:12
I read in the book "Letter Series Farmalls" that these letters represented options such as high altitude, low altitude, diesel, gas, distilate and so on. I to have a 1949 C which is a fuel burning tractor. hope this helps.
Athol Carr
05-03-2007 02:29:34
The FCM means Farmall C Motor, A w-4 has serial number prefix WBH and engine has WBHM
Dave in nb
05-03-2007 04:40:12
 Re: Farmall C identification in reply to Athol Carr, 05-03-2007 02:29:34
That makes sence, but what about the G. Is this a factory code?
Tractorfan1
05-02-2007 19:52:28
Welcome Dave! Which part of New Brunswick are you from? I too am from NB, between Fredericton and Woodstock.
Brett
Dave in nb
05-03-2007 03:52:37
 Re: Farmall C identification in reply to Tractorfan1, 05-02-2007 19:52:28
Brett
I live just outside of Woodstock. Are you from the Nackawic area. What kind of Farmall do you have? i"ve just started with mine, it was in rough shape when I got it. It ran rough but I"m hoping a new coat of paint and some TLC in the Engine department will fix the old girl.
Tractorfan1
05-03-2007 05:13:45
 Re: Farmall C identification in reply to Dave in nb, 05-03-2007 03:52:37
Im from Zealand. We have an H, Super M, 2 Cub's and an 806D on the place. I also have a few IH collectables. There is a boat load of old letter series farmalls in this area, with just a few 06 series.
Brett
dcw
05-02-2007 16:41:23
Hi Dave.I too am a Dave from NB,and I had a 50 Farmall C,WHICH STILL HAD THE ORIGINAL 113 PISTONS AND SLEEVES IN IT.It was more expensive for me to buy rings for the 113 pistons than it would have been to replace them and the sleeves with 123 parts.If your engines been overhauled,it likely has 123 pistons and sleeves in it.
I don't believe that there is a difference in the head gaskets,since the package claimed it was for 113,123,and I believe C135.
dave in nb
05-02-2007 18:18:18
 Re: Farmall C identification in reply to dcw, 05-02-2007 16:41:23
Thanks dave
Can you answer my first question about the M & G
Randy in NE
05-02-2007 14:59:32
The C came with a 113 CID engine with 3" bore and 4" stroke. Some of them have been bored out to 3 1/8" bore making it a 123 CID which is the same as in the Super C. You won't know for sure until you pull the head. When I replaced the head gasket on one of my C's I found out that it had been bored out. It is hard to find a head gasket for a 123 CID C engine which is a thermosyphon system. The Super C water ports are much smaller than the C.
teddy52food
05-02-2007 16:23:25
 Re: Farmall C identification in reply to Randy in NE, 05-02-2007 14:59:32
The head gaskets are the same for 113 or 123 ( ABC super A&C ) except it makes a difference if it has a water pump or not. The one with the smaller holes is used with the pump.
Randy in NE
05-03-2007 04:55:34
 Re: Farmall C identification in reply to teddy52food, 05-02-2007 16:23:25
The head gasket that I got for the C (113 CID) had a smaller diameter opening for the cylinders. The one for the Super C (123 CID) had room for the 3 1/8" pistons but had the smaller water ports because of the water pump.
