Re: loading 1466 tires
georgeky
05-03-2007 11:00:12
It will make a difference, but fluid will damage the rims after a while. I would consider weights and maybe a set of duals pulling that big a disk. Check the tire pressure, if it is above 10 or 12 lbs it will cause a lot of slippage.
Yellott Canby
05-03-2007 11:27:42
 Re: loading 1466 tires in reply to georgeky, 05-03-2007 11:00:12
Thanks for the input. I have a couple of half moon weights on each side, but thought calcium would add more weight than I could even put on in cast iron.
old
05-03-2007 12:39:19
 Re: loading 1466 tires in reply to Yellott Canby, 05-03-2007 11:27:42
You might also try beet juice or wiper fluid in the tires. Its not as heavy as CACL but its also not hard on the rims if you get a leak. My self I fill my own tires since labor for it will be around $100 or more. Also filling them will make a big differacne
