1066 4WD
cliffr
05-03-2007 12:21:03
I'm in the process of restoring an old 1066 and was thinking about converting it to 4WD. I have the name of a company that used to make these kits named elwood but I haven't found anything on them except they went out of business. Does anyone any suggestions about how I should go about this? Maybe going out and getting stock parts off salvaged tractors or is there somewhere else aftermarket to look? Any help would be appreciated!!
Armand Tatro
05-03-2007 16:18:23
 Re: 1066 4WD in reply to cliffr, 05-03-2007 12:21:03
Did I.H. ever offer a 806D with factory MFD? There was one in the Herscher, Ill. area. It had a chrome plate stamped 4 wheel drive as I remeber it and huge rear tires. I think it is still around. (The chrome piece may not have been word for word as I have stated. Armand
Nat 2
05-03-2007 13:33:02
There were two companies that made axles for these conversions, Elwood, and Coleman. Both companies are either out of business, or not involved in making axles for 30-year-old tractors.
Your best bet will be salvage parts.
If you're good at fabricating, you can adapt a heavy truck axle, but it's a lot of work figuring out the ratios and getting the driveline working.
Your best bet will be salvage parts. Definitely.
cliffr
05-03-2007 14:29:04
 Re: 1066 4WD in reply to Nat 2, 05-03-2007 13:33:02
Any idea on how difficult it may be to get these parts salvage?
FRED EAGERTON JR.
05-09-2007 21:26:00
 Re: 1066 4WD in reply to cliffr, 05-03-2007 14:29:04
THEY ARE OUT THERE, BUT THEY ARE PRICEY, THOUGHT OF CONVERTING A 1466, CHEAPEST I COULD FIND WAS 2K
