BobM - 454 Wiring Question
TDK
05-03-2007 12:38:52
Tractor is gas with Delco alternator w/ external regulator. Witing is burned so I have nothing but diagrams(yours & others) to go by. My question is,,, why is the why is the "R" plug on alt. not used ? Per diagrams('65 Chevrolet) - Batt. hot lead from alt. to #3 on regulator,,,,"F" on alt. to "F" on reg.,,,,,"R" lead on alt. to #2 on reg. and #4 on reg. to amp. gauge. What is the "R" for and why is it not needed on this tractor. P.S. - this is same tractor that I posted the question about it having a diode in the wiring a few weeks ago.
Bob M
05-03-2007 13:40:25
 Re: BobM - 454 Wiring Question in reply to TDK, 05-03-2007 12:38:52
TDK - It's been a while since I messed with an externally-regulated Delco alternator. However if memory serves the alternator's R terminal is used only when a dash-mounted charging system idiot light is installed.
So if your 454 has got an ammeter and not an idiot light, no connection is required to R.
Hopefully someone else can confirm!!
TDK
05-03-2007 17:31:11
 Re: BobM - 454 Wiring Question in reply to Bob M, 05-03-2007 13:40:25
It does have an amp gauge. After some further study, you seem to be correct. I appreciate your help.
