350 FastHitch
agpilot
05-03-2007 14:39:51
Hello Everyone: It is over a two hour drive to the 350-rc that I am buying so I'll ask here how much of a margin there is in the width between the two Fast-hitch "spears" or points that can be plugged into the 350 FastHitch.? I can have access to getting several items that have the two IHC fasthitch points welded to them. There is a plow and spring tooth digger. A flat drawbar and a frame with a large spray tank. A couple of 2 point plug-ins that convert out to use 3 point equipment...etc ( I measured all items on the flat area where points are locked in rather then guess at a centerline on a rounded area of the points.) Most points seem to be parallel. What is "correct" factory distance between the two points? What's the Min-Max width that a 350 FH can normally tolerate? Thanks much... agpilot
georgeky
05-03-2007 14:46:59
 Re: 350 FastHitch in reply to agpilot, 05-03-2007 14:39:51
27 and 1/2 inches center to center.
agpilot
05-03-2007 16:52:43
 Re: 350 FastHitch in reply to georgeky, 05-03-2007 14:46:59
Hello George: No tolerance?
Anyone else use equipment that has slightly wider spacing on the points?? How wide? Thanks as I can't take over two hours to drive there to check this 350. agpilot
georgeky
05-03-2007 17:17:44
 Re: 350 FastHitch in reply to agpilot, 05-03-2007 16:52:43
They pretty much have to be right or it will not slide into the sockets very easily, or come out easy either. All fast hitches are this wide. The only difference is on the smaller tractors such Super C, 200, and 230 and they used prongs that were a little smaller, but the same width.
