Small hose for ether injection system.
Bradford
05-03-2007 18:35:23
my 826 doesn"t have the ether injection system on except the fitting in the air intake.
The small diameter tubing doesn"t seem to be available.
Does anyone have an idea for a substitute? Just need something that will work short term.
georgeky
05-04-2007 13:55:56
 Re: Small hose for ether injection system. in reply to Bradford, 05-03-2007 18:35:23
That should be available at IH, I got one last year for my 584. Call 1-888-824-0544 Ask for Brad.
glennster
05-04-2007 06:08:54
try a truck supply store, they have the hot shot kits for semi's, they should have the tubing. another place to check is a construction supply for heavy equipment, they would have them too. our old case 1845b skidsteer had the hot shot kit on it.
Wardner
05-04-2007 01:33:13
I think it is the same tubing used for oil pressure guages. It can be had in either copper or plastic. If it is not available at an auto parts store, try a good hardware store or a plumbing supply house.
You will need the manual or electric valve anyway. The tubing should be in the kit.
A salvage yard that has big trucks should have everything you need. Portable air compressors, gensets, and most large equipment should also be a good source.
Tan67
05-03-2007 19:06:32
Dont know much about the eithering, I try to stay away from it but neither about injecting it but maybe some 1/4 inch gas line will work."posibly Maybe"
