farmall h rim problem
vermontmat
05-05-2007 15:47:57
replaced one rim on my h with adouble step 10 inch rim,the center is wider and the clamps dont tighten correctly.is the rim just wrong,or is there a fix?thanks!
GordoSD
05-06-2007 05:55:47
 Re: farmall h rim problem in reply to vermontmat, 05-05-2007 15:47:57
I just bought a drop center 11 inch rim for my Super H. It came off an M. I had to search high and wide for this rim. Seems no one makes that one, and they are pretty scarce. I paid 125 dollars, but the rim is near perfect, have never seen a better used one. So if you all see a fence row Farmall with two good drop center rims figure it has 250 dollars worth of rear rims alons. I found dozens of bevel rims cheap! I wouldn't trade that wider drop center for three bevel rims! SHop accordingly.
Gordo
georgeky
05-05-2007 20:33:39
As CNKS said you have the wrong rim for an H. You can use it, but will need the clamps from a 300/350 or something along those lines.I would take it back and try to find the right one.
CNKS
05-05-2007 19:05:45
From your description you have the wrong rim. Other interpretations -- if by double step, you mean drop center and it is the one for your tractor, it will bolt on with no problem. If it is a double bevel rim, the original clamps won't fit. I do not know if the later clamps will fit the H or not.
