Replacing starter on 42 H
Redlin49
05-05-2007 16:49:37
I am replacing the starter on my dad's 42 H with a new aftermarket starter. Will I need to be concerned about shimming it or should I be able to bolt it on and run? If I do need to shim it, where would I be able to see if there is enough clearance between the fly wheel ring gear and the starter gear?
GordoSD
05-06-2007 05:47:53
 Re: Replacing starter on 42 H in reply to Redlin49, 05-05-2007 16:49:37
I live in a small town of 13k people and there are three shops that rebuild starters. You get them back looking better than new, still have original D/R plate and will last your lifetime. Check out that option. ( oh, the cost is trendy, about 70 dollars.
Gordo
old
05-05-2007 19:05:11
99% of the time they work just fine, since they are made to fit your tractor. Shoot you can use a good number of starters on them. Ones from a B, A, C, H, and M will all fit but some don't have the torque that to ones that came on them when new have. H starter are easy to find this site, valuebilt and many many other have them
Tom Windsor
05-05-2007 18:40:18
I will bet that there is a proper way to do it other than what I am about to say.
I would bolt up the starter, hook it up and tap the starter button. If it needs shims, you will know immediately.
TW
