Farmall 450 LP engine speed control
Albert Pereira
05-05-2007 20:43:13
Hello, I just purchased a Farmall 450 on LP the speed control lever needs to be at full throtle just to idle and start the tractor, and almost straight down to idle up enough to drie and pull a little. The linkage is by no means new, but there is not that much play in it. I diconected it from the governor that throtled it up it was a little better but not much. Is there an adjustment to increase the engine speed in the governor or on the regulator or carb. Please help this is my first LP tractor and have no expereince on them. Also is there a place that sells the little gasket at the bottom of the three hydro levers there are four bolts and it bolts to the bottom of the hydro controls. Thanks
the Unforgiven
05-05-2007 21:30:24
 Re: Farmall 450 LP engine speed control in reply to Albert Pereira, 05-05-2007 20:43:13
Hi Albert, I don't think it is an lp problem. You should not have that much travel with the throttle lever, maybe check for a sheared pin in the linkage connections, I had one act just like yours.
