International 260a Backhoe
JoelD
05-06-2007 05:21:37
HI all,
Looking at one of these machines, the hoe swing shaft and bracket are extremely worn, the shaft teeth and the bracket have worn to the point where they"ve almost spun.
Looking for thoughts on level of effort to fix.
Any other weak points on these machines? How hard is it to get parts? I"ve never replaced pins and bushings on a full sized machine just my home-built little backhoe. Are pins and bushings available for this machine, particularly for the hoe bucket.
Thanks all for taking the time to read and respond, help is greatly appreciated.
Joel
JayWalt
05-06-2007 05:50:02
 Re: International 260a Backhoe in reply to JoelD, 05-06-2007 05:21:37
Joe, if you cant find pins and sleeves/bushing, a local machine shop outta be able to make/get them for you, just take the old ones in with you.
JoelD
05-06-2007 06:05:15
 Re: International 260a Backhoe in reply to JayWalt, 05-06-2007 05:50:02
Thank you Jay,
I guess this would not be a big deal as I read your response and think about mechanically what would be done.
It's the hoe swing that worries me the most.
Any thoughts on how much one of these machines is worth? No smoke at startup, some smoke under load. hour meeter broken. Runs cool, and electrics work.
Thanks again,
Joel
