m not starting
james in mo
05-06-2007 15:44:12
my farmall m is not starting. it has spark every where. it has gas. and yes the gas is turned on. i have cranked and cranked allot but no results. is this just flooded or ?
Rootsy
05-07-2007 08:56:44
 Re: m not starting in reply to james in mo, 05-06-2007 15:44:12
To start a flooded engine open the throttle wide open and crank. the massive inrush of air will help clean out the fuel laden cylinders and it should pop off without a whole lot of issue, if that is indeed your problem... just be ready to throttle her back down as she is going to go WOT since it is in that position... SOP
georgeky
05-06-2007 15:47:54
Is gas dripping out of the carb? You might take out a plug or two and see if they are soaked with gas. If it is not flooded I would try a new condensor.
james in mo
05-06-2007 15:51:08
 Re: m not starting in reply to georgeky, 05-06-2007 15:47:54
i forgot to say one thing, it was runing just fine a minute before, and only died when i poped the clutch on 5th.
John S-B
05-06-2007 16:02:31
 Re: m not starting in reply to james in mo, 05-06-2007 15:51:08
Could the distributor have been knocked out of time? maybe check the timing, it might be possible the jerk did something to the timing.
georgeky
05-06-2007 15:59:53
Try pulling it and see if it will start. Or if it is flooded drain the carb and just wait a while and try again. Do you have spark at the plugs or have you checked one? Just because there is spark at the points don't always mean there is at the plugs.
