NH 320 behind an M?
eryp
05-06-2007 17:10:16
I've come across a NH 320 small square baler for a decent price. I believe that NH recommends a minimum of 50 HP to run this machine. I know the M is not putting out that much but I thought that maybe the 50 hp is an overstatement.
Anybody think I'd be able to pull this thing ok?
Jason Simmerman
05-07-2007 03:11:00
 Re: NH 320 behind an M? in reply to eryp, 05-06-2007 17:10:16
My dad in the past has run a NH 310 and it runs it OK. That is alot of baler and like others said the lack of a IPTO makes baling a challenge with it. The balers he has used also had throwers on them. He lost a clutch the one year using the 310 and not being able to slip it out of gear fast enough. Be careful and it should go ok
foothill
05-06-2007 18:21:55
the 320 was the largest capacity baler baler NH made, over 100 strokes a minute. it could eat a lot of hay but it really 'rocks' the tractor. I have ran one for years with a 85 hp tractor.
Steven@AZ
05-06-2007 17:59:05
Dad ran a NH 67 square baler for many years with an H. An M should be no problem at all.
Live PTO is nice with a square baler, but you will get good at seeing a heavy spot and sliding the tractor out of gear... or making smaller windrows.
georgeky
05-06-2007 17:23:49
Your M will pull it anywhere. The lack of live power can be a challenge sometimes. The ground speed can be to fast in really thick hay. I rake smaller windrows to allow for that.
eryp
05-06-2007 17:30:17
 Re: NH 320 behind an M? in reply to georgeky, 05-06-2007 17:23:49
Thanks for the input. I think I'm going to pick up that baler next weekend. I'll let everyone know how it goes after the 1st cut.
Eric
georgeky
05-06-2007 17:57:56
 Re: NH 320 behind an M? in reply to eryp, 05-06-2007 17:30:17
The old M is a lot more tractor than some folks give them credit for. I think HP then was different than now. I have baled lots of hay with one in the past. I use a 350 diesel now because of the IPTO and fuel consumption. I wish the M had IPTO and I would use it, I love to hear that thing purr.
eryp
05-06-2007 17:12:22
Oh yeah, it's a 1942 M.
