C gas tank
Karl Hamson
05-06-2007 19:04:34
A day of dreary rain instead of the promised sunshine so I decided to tackle the fuel starvation problem on my C. I pulled the tank and as expected there is lots of rust and other crud. Any good ideas about getting this stuff out? I thoughtI might throw in a few pounds of clean pea gravel, put on some good rock and roll and shake it. The paint is pretty good so I don't want to send it in to get tanked.
I have read here about extending the inlet upward 1/2" or so which seems to be a good idea except you can never drain the tank should you ever want to. I thought I would stick a piece of 1/4" copper tube into the existing hole. Will this restrict fuel flow too much?
Also the gasket for the sediment bowl is bad. I have some 1/8" sheet neoprene will this stuff work or will the gas attack it?
Thanks, Karl
tn terry t
05-06-2007 19:24:33
 Re: C gas tank in reply to Karl Hamson, 05-06-2007 19:04:34
put you some nuts and bolts in there and strap the tank to another tractor rear tire and go for a ride that will "git-er-done"
georgeky
05-06-2007 19:10:35
I don't know about your gasket material, but bolts, nuts and what have you will help the tank when shaken around.
