C gas tank
Karl Hamson
05-06-2007 19:09:42
A day of dreary rain instead of the promised sunshine so I decided to tackle the fuel starvation problem on my C. I pulled the tank and as expected there is lots of rust and other crud. Any good ideas about getting this stuff out? I thoughtI might throw in a few pounds of clean pea gravel, put on some good rock and roll and shake it. The paint is pretty good so I don't want to send it in to get tanked.
I have read here about extending the inlet upward 1/2" or so which seems to be a good idea except you can never drain the tank should you ever want to. I thought I would stick a piece of 1/4" copper tube into the existing hole. Will this restrict fuel flow too much?
Also the gasket for the sediment bowl is bad. I have some 1/8" sheet neoprene will this stuff work or will the gas attack it?
Thanks, Karl
Kyle Super C
05-07-2007 08:14:51
 Re: C gas tank in reply to Karl Hamson, 05-06-2007 19:09:42
Hard to say about the effects of gasoline on the neoprene. If you wanted to take the time, you might just take a piece of the neoprene & let it soak in gas for a week or so, see if it appears to soften or break down the edges.
A. Bohemian
05-07-2007 10:26:03
 Neoprene and Gasoline in reply to Kyle Super C, 05-07-2007 08:14:51
Neoprene is commonly used as a fuel line. I am not sure about its suitablility as gasket material.
BF8690
05-06-2007 20:05:49
Gravel for a fish tank works great. You can even choose a size that will work but not damage the paint.
gene bender
05-06-2007 19:30:11
Just go to NAPA and get new gasket and screen. Take the old along so you get the correct size. Yes a short piece of tube on the thread end of the sediment bulb assy works fine. If you think you need to drain the tank just un-screw it and drain.
