Farmall BN continued
Paul U
05-07-2007 04:59:03
Well this weekend I went to Vermont to pick up the BN. A couple of things, the serial number plate indicates it as a BN. Serial number was 109506. so it was bulit in 1944. The tractor was rougher than I thought. The side walls on the tires were cut wide open, the intake/exaust manifold was rotted through. But the worst problem was this. I belive the battry mounts over the casting that connects the engine to the transmission? There was a lot of corosion on the housing. So much that there were holes eaten through the housing. Is this common? Needless to say, I did not purchase the tractor without discussing it with the forum
farmallkid1958
05-07-2007 05:32:15
 Re: Farmall BN continued in reply to Paul U, 05-07-2007 04:59:03
HI: It would take quite a bit for battery acid to eat thru a cast iron housing. I have seen battery boxes go, but not the housing. I have a farmall B that I am parting out and have a good housing if you need one. The housings for the B & BN are the same. Give me a shout back if you are interested in it. I am in Indiana. Hal
